Enables sending SNMP trap when saving or changing the switch configuration.
configuration | Sends SNMP trap for switch configuration. |
save | Generates SNMP trap when switch configuration is saved (default is disabled). |
change | Generates SNMP trap when switch configuration is changed (default is disabled). |
The default is that SNMP traps are disabled for switch configuration changes/saves.
The following example enables SNMP traps for switch configuration changes:
enable snmp traps configuration change
This command was first available in ExtremeXOS 22.1.
This command is available on all Universal switches supported in this document..
